Copen 1.3 => 1.5 = more fun driving!
Discussion in 'Modifications' started by jcuyckens, Jul 12, 2016.
  1. jcuyckens
    jcuyckens Copenworld Member
    Belgium
    Volvo XC60 2015
    Toyota Corolla 2004
    Rover 45 V6 2005
    Daihatso Copen 2006
    BMW R850RT & R850R
    Yamaha GTS1000 1993
    Hello,
    it took me almost two month but finally finished.
    I've installed a 3SZ-VE (1500cc) from a Terios into the copen 1.3 chassis.
    Original engine was K3-VE (1300cc).
    Now the copen has a healty 107HP. Getting moving and accelerating faster!
    Driving fun really increased significantly.
    This modification is not an easy swap. New engine block has an almost identical cast iron base, but it's height is + 2.5cm. Valve ports are bigger also, so better performance.
    A list of adjustments:
    Servo pump bracket from other origin
    Airco compressor bracket alu from other origin
    Calatysator bracket 1.3 + mm
    Coupling 1.5 Terios
    Coupling cable 1.3 +mm
    Coupling lever/cable
    Carter + oil pump suction 1.3
    Distribution chain cover 1.5
    Pulleys 1.3
    Flywheel 1.3
    Alternator belt tensioner from other car
    Thermostat housing 1.3
    Oil filter housing 1.3
    Motor supports 1.3
    Transmission 1.3
    Subframe lowered 10mm to be ablo to close the hood
    Front spring + 8mm, kidney flange to compensate Mini Rims
    Front spring + 6mm, piston under bearing to compensate lowered subframe
    Exhaust and cataliser 1.3 fits.
    Exhaust bushing +20mm to compensate higher engine block
    Air intake YRV turbo, this fits 1.5 trottle valve
    K&N air filter + housing (surplus)
    Engine bay cables 1.3
    All sensors 1.3
    ECU (+ABS!) 1.3
    Cooling water hoses 180° and 90° new silicone
    Fluel pressure regulator 1.3
    Oil filling cap 1.3 because it is lower
    Next step: chiptuning.
    3SZ-VE coupling-800.jpg 3SZ-VE_10mm lowered sub_frame-800.jpg 3SZ-VE_new motor-800.jpg 3SZ-VE_sub frame-800.jpg 3SZ-VE_timing chain cover-800.jpg 3SZ-VE coupling-800.jpg 3SZ-VE coupling-800.jpg 3SZ-VE_10mm lowered sub_frame-800.jpg 3SZ-VE_new motor-800.jpg 3SZ-VE_sub frame-800.jpg 3SZ-VE_timing chain cover-800.jpg 3SZ-VE coupling-800.jpg 3SZ-VE_10mm lowered sub_frame-800.jpg 3SZ-VE_new motor-800.jpg 3SZ-VE_sub frame-800.jpg 3SZ-VE_timing chain cover-800.jpg 3SZ-VE coupling-800.jpg
    iamkkool and Your Majesty like this.
  2. Bemused
    Bemused Copenworld Regular
    Stoke-on-Trentishoe
    Great detail, thanks for sharing.
    Your Majesty likes this.
  3. Salieri
    Crazy, what are the 0-100 times?
  4. ilbuonmarcio
    ilbuonmarcio Copenworld Newbie
    Verona, Italy
    Daihatsu Copen L881K 1300cc straight piped and chiptuned, in the future I'm studying an engine swap with a 3SZ-VE
    Hi @jcuyckens, how did the swap experience and reliability went for you until now?
    I'm interested in trying this new chapter for my 1300cc Copen, after I already have done a brakes front and back upgrade, a full intake with Sparco HP160, aftermarket exhaust manifolds from MaxRacing and a full straight pipe exhaust system, with a touchup with a chiptuning chip made by me for the airflow temperature sensor, and so far the difference is very noticeable.
    But I haven't yet pulled the trigger on the new engine because there are no others around talking about that other than you, so I'd think asking that after some years is a good way to let us know if it's all smooth and well or problems have risen for example the clutch or the gearbox in general :)
    Thanks for your time!
