changing the front smaller lights
Discussion in 'Problems, Fixes, Tips...' started by dsb, Aug 26, 2013.
  1. dsb
    not the headlights....
    the manual says unclip the plastic cover above the wheel.
    it seems to be held in place by flat plastic rivets - if I pull are they going to come out and (more importantly) pop back in once I'm done?
    i'm a bit wary of giving it a big tug and ripping something off that won't go back on.
    If I remember correctly the plastic clips have a circular pin in the centre.
    Pry that centre not up with a flat screw driver. The clip will then lift free. To re-use just press the centre bit back into place to lock it.
  3. dsb
    it's a sunny day so... better get outside and try....
