Catalogue with Daihatsu part numbers
Discussion in 'Problems, Fixes, Tips...' started by ronalddoes, Feb 10, 2017.
  1. ronalddoes
    ronalddoes Copenworld Member
    The Netherlands
    The workshop manuals over at the resources section have proven to be absolutely pricesless. However, at least for the 659cc turbo, they don't contain a part number catalogue.
    I found the attached PDF online. It contains a lot of parts with Daihatsu part numbers and sometimes helpful diagrams. Makes searching for parts online a lot easier. Maybe it can be of help to you as well.
    Does anybody have an original parts catalogue by Daihatsu?
    copenco and Salieri like this.
    nnnnnnnnnnnnnnnnnnnnnnice
  3. Number6
    I have access to Daihatsu's (very old) parts catalogue software. It's on an old desktop computer I got from a mechanic.
  4. jcuyckens
    jcuyckens Copenworld Member
    Belgium
    Volvo XC60 2015
    Toyota Corolla 2004
    Rover 45 V6 2005
    Daihatso Copen 2006
    BMW R850RT & R850R
    Yamaha GTS1000 1993
    Hello, do these have the cross sectional drawings with part numbers for the Copen? Turbo or 1.3?
  5. Salieri
    Is there any chance to get this software? :D
  6. ronalddoes
    The Netherlands
    That sounds really, really interesting. Do you think there's any way to copy this software (or the database)? I'd love to try and make it available to everybody.
  7. Number6
    I've been trying on and off for the last month or two to no avail. Without the installer, it's gonna be difficult, as the installer modifies the Windows registry and I'm not too sure how - simply copying the program folder to another computer makes the program crash, and it doesn't want to even attempt to load/crash on anything other than Windows XP.
  8. Vin Petrol
    If it's a small number of pages of copen parts, what about just screen shots?
  9. ronalddoes
    The Netherlands
    Storing them in a PDF would make them sort of searchable again.
    That'd be a great, great help to a lot of us, I'm sure.
  10. Number6
    There are about 200 pages of images, as explosion diagrams. The part numbers are NOT listed in an image - you have to click what you want to get the part number.
    I am not bored enough to go through each image and put part numbers on them - it would take days
    Vin Petrol and ronalddoes like this.
  11. ronalddoes
    The Netherlands
    I understand. Too bad.
  12. Salieri
    My daihatsu dealer also has this program and I can confirm Number6's post. The program is quite clumsy :D
  13. Vin Petrol
    Daihatsu Copen genuine parts list
    It is a list of expendable parts of Daihatsu Copen, manufacturer options, and classic diversion parts.
    [​IMG] Repair parts etc. which are not displayed on regular page are also listed.
    ■ Daihatsu Copen genuine parts
    name Item name part number List price Remarks
    Rear performance brace right Front Floor Brace RH 65365-97201- 1,250 yen Supplementary explanation
    Left performance brace left Front Floor Brace LH 65366-97201- 1,250 yen Supplementary explanation
    Bolt 8 x 25 mm With Washer Bolt 91651-60825-000 100 yen 2 required
    Cross member bolt (wide washer) With Washer Bolt 57179 - 97202 - 260 yen #
    Cross member bolt With Washer Bolt 57179 - 97203 - 260 yen #
    Bolt 6 × 12 mm bolt 91621-60612-000 150 yen # For engines
    Bolt 6 × 12 mm With Washer Bolt 90041-20174- 100 yen # For fender
    Bolt 6 × 14 mm With Washer Bolt 91631 - G 0614 - 50 yen # Bonnet fixing
    Bolt 6 × 14 mm With Washer Bolt 91651-60614-000 60 yen # For fixing the ABS stay
    Bolt 6 x 15 mm With Washer Bolt 90119-06915-000 50 yen # For earth
    Bolt 6 x 18 mm With Washer Bolt 90119-06923- 50 yen # For earth
    Bolt 6 × 14 mm With Washer Bolt 91621-60614-000 110 yen # For air cleaner fixing
    Bolt 6 x 20 mm With Washer Bolt 90041-20104-000 130 yen # Engine cover back side
    Bolt 6 x 25 mm With Washer Bolt 90041-19980- 100 yen # For fixing the engine cover
    Bolt 8 x 25 mm bolt 91621-60825-000 90 yen # For engines
    Flange nut 8 mm Flange nut 90041-79300- 110 yen #
    Seat Belt Guide Right Front seat guide RH 73187-97202- 1,050 yen Supplementary explanation
    Seat Belt Guide Left Front seat guide LH 73187-97203- 1,050 yen Supplementary explanation
    Flange nut 6 mm Flange nut 94150-80600-000 50 yen 2 required
    Screw bolt 6 x 15 mm With Washer Screw 90041-59316- 90 yen 2 required
    Roof Lock Spring Spring, removable roof 63279 - 97201 - 250 yen 2 required
    CopenS sticker right Plate, quarter panel name, light 75381 - 97201 - 1,480 yen
    CopenS sticker left Plate, quarter panel name, left 75382-97201- 1,480 yen
    Hook for floor mat Base hook 08219 - K 2007 - 280 yen
    Fender clip Grommet screw 90041-89021- 100 yen #
    AFR0N1 and copenfangrl like this.
  14. Vin Petrol
    Grommet for door grip fixing screw Grommet screw 90041 - 89030 - 110 yen #
    Clip for lining (white) Quarter clip 90467-10161- 80 yen #
    Clip for inside of trunk · Fr console clip 90044-68061-N1 130 yen #
    clip clip 90044-68320- 160 yen #
    Clip (screw type) clip 90044-68149- 280 yen #
    Clip (V type · pink) clip 90044-68324- 100 yen #
    clip clip 90044 - 67357 - 90 yen Snow cover · Cold area specification
    Engine under cover right Engine under cover 51441 - 97201 - ¥ 780 Snow cover · Cold area specification
    Engine under cover left Engine under cover LH 51442-97201- ¥ 1,110 Snow cover · Cold area specification
    Engine cover Engine cover ASS No. 1 12601 - 97201 - 5,300 yen #
    Rubber for fixing the engine cover Grommet 90044-80625- 210 yen #
    Bonnet support securing clip Bonnet (hood) support rod clamp 53455-97203- 210 yen #
    Sponge on bonnet back radiator Cooler packing No. 1 88578-87274- ¥ 640 # 375 × 30 × 15 mm
    Engine room rubber packing Plug Hole 90048-71200- 100 yen #
    Cowl top long rubber Bonnet (hood) two-cowl top seal 53383 - 97207 - ¥ 1,100 #
    Oval vents on the cowl top Cowl vent cover RH 55877-97201- 600 yen # 3 required
    Black cover around battery (standard specification) Battery cover 74405-97202- 3,000 yen #
    Black cover around battery (cold district specification) Battery cover 74405-97203- ¥ 3,400 # W 20 x D 13 x H 18 cm
    Battery case Battery carrier 74043 - 97201 - ¥ 3,450 #
    Complete aero deflector Window Deflector Board 63230 - 97201 - C 0 ¥ 8,300 # Supplementary explanation
    On the deflector roll bar side part Windshield support bracket retainer 56363 - 97201 - C 0 100 yen # Supplementary explanation
    Under the deflector roll bar side part Windshield support bracket 56361 - 97201 - C 0 150 yen # Supplementary explanation
    Deflector fixing parts Windshield stopper bracket 55719 - 97201 - C 0 450 yen # Supplementary explanation
    Bolt female for fixing the deflector Nut, cap 15542-97201- 180 yen # Supplementary explanation
    Bolt aus for fixing the deflector Bolt, board set 73947-97201- 180 yen # Supplementary explanation
    Tapping screw for fixing the deflector Screw, Tapping 90041-67041- 100 yen # Supplementary explanation
    Late model sun visor right Visa ASSY RH 74310-97246-N1 1,680 yen #
    Late model sun visor left Visa ASSY LH 74320-97234-N1 1,680 yen #
    Roof lining Roof head lining trim FR 63748-97201-N1 3,000 yen #
    Bolt 6 x 20 mm With Washer Screw 90041-59446- 100 yen # For locking the roof lock
    Dashboard cushion Instrument panel cushion 55355-97201- 450 yen #
    copenfangrl likes this.
  15. Vin Petrol
    Side brake cover (rubber cover) Parking brake dust cover 46524 - 97201 - C 0 700 yen #
    Cover under side brake grip Console box front cover 58818-97201- ¥ 330 #
    Plating shift plate for AT Console box bezel 58844 - 97201 - ¥ 2,900 #
    Cover inside console box Console box rear cover 58917-97201- 430 yen #
    Console box fixing grommet Grommet screw 90041-89039- 110 yen # White
    Console box fixing grommet Grommet screw 90041 - 89058 - 100 yen # black
    Air conditioning outlet ring Instrument panel register opening cover 55526-97201-C0 ¥ 750 #
    Air conditioner control back seat Heater control name sheet, NO.1 81942-97224- 1,140 yen #
    Center panel Instrument Cluster Finish Center Panel ASSY 55420-97204-N1 4,500 yen #
    Meter panel Instrument Cluster Finish Panel ASSY 55410-97201-N1 ¥ 3,500 #
    Meter clear panel Combination meter glass 83138 - 97401 - 1,240 yen #
    Steering column cover Cover, steering column, upper 45286-97217-N1 1,470 yen #
    Under steering column cover Cover, steering column, lower 45287-97208-N1 ¥ 1,960 #
    Steering lower cover Instrument panel finish panel LWR NO.1 55432-97206-N1 ¥ 2,350 #
    A pillar lining right Front pillar garnish RH 62211-97207-N1 ¥ 1,600 #
    A pillar lining left Front pillar garnish LH 62212-97207-N1 ¥ 1,600 #
    Seat back lining right Quarter trim panel ASSY FR LH 62510-97205-N1 3,550 yen #
    Left seat lining left Quarter trim panel ASSY FR RH 62520-97205-N1 3,550 yen #
    Inner lining upper right of the seat Quarter trim panel UPR RH 62635-97201-N1 ¥ 2,650 #
    Left lining of the seat upper left Quarter trim panel UPR LH 62636-97201-N1 ¥ 2,650 #
    On the lining of the seat back lining Back panel trim ASSY 64270-97201-C0 1,860 yen #
    Center lining lining center (with pocket) Back panel trim 64271 - 97201 - C 0 ¥ 7,900 #
    Opening cover Rear window shade ASSY 64333 - 97202 - C 0 23,000 yen #
    Opening cover bag Rear window shade cover 15111-97201- ¥ 7,600 #
    Trim for opening cover Package tray trim cover 64332 - 97204 - C 0 18,700 yen #
    Opening cover storage hook Package Tray Trim Panel Hook 64338-97201- 1,050 yen # 2 pieces required
    OP cover storage hook fixing bolt 6 x 50 mm bolt 91651-60650- 90 yen # 2 pieces required
    Rear tray board Package tray trim panel ASSY 64330-97207-C0 ¥ 7,100 #
    Back lining in trunk Room partition board ASSY 64716-97206-N1 4,900 yen #
    Damper supporting trunk (common to left and right) Trunk panel (luggage compartment door) stay ASSY 68950-97211- 4,200 yen # A For the top
    Intercooler side Plat plate (center) Radiator Grill Side Air Guide RH 53153 - 97202 - ¥ 1,970 #
    Radiator side platter board (left) Radiator Grill Side Air Guide LH 53154 - 97201 - ¥ 1,970 #
  16. Vin Petrol
    On the radiator hose Hose, radiator, inlet 16571 - 97204 - 1,050 yen #
    Under the radiator hose Hose, radiator, outlet 16572 - 97206 - 1,880 yen #
    Radiator Drain cock packing Radiator drain cook packing 16442-97201- 90 yen # 6 mm - 10 mm
    Cap & hose for radiator tank Cap sub-assembly, reserve tank 16405-97202- ¥ 970 #
    Blowby piping L letter rubber hose Ventilation hose 12261-97211- ¥ 330 #
    Hose (8 × 950 mm) Vacuum hose 95411-19995- ¥ 1,190 #
    Hose (9 x 120 mm) Air bypass hose 17134 - 97201 - 440 yen #
    Hose clip (7 mm in diameter) clip 90044 - 67122 - 160 yen #
    Hose clip (diameter 11 mm) Hose clip 96132-41000-000 ¥ 70 #
    Hose clip (diameter 13 mm) Hose clip 96132-41100-000 90 yen #
    bonnet Bonnet (hood) 53301 - 97223 - ¥ 21,000 # Unpainted
    Trunk panel Trunk panel (luggage compartment door) 64401 - 97203 - 35,800 yen # Unpainted
    Front bumper Front bumper cover 52119-97240 - ## 33,100 yen # Each color
    Rear bumper Rear bumper cover 52159-97239 - ## 35,400 yen # Each color
    Inner in rear fender Right Rear wheel house liner RH 65637 - 97201 - 3,600 yen #
    Inner left in rear fender Rear wheel house liner LH 65638-97201- 3,600 yen #
    Tail lamp right Tail lamp (rear combination lamp) ASSY RH 81550-97246- ¥ 9,900 #
    Tail lamp left Tail lamp (rear combination lamp) ASSY LH 81560-97246- ¥ 9,900 #
    Clip for tail lamp Clip, rear combination lamp 81559 - 97209 - 160 yen # 2 one side required
    Back & blinker lamp right Backup Lens Lens & Body 81671 - 97203 - 8,600 yen #
    Back & blinker lamp left Backup Lens Lens & Body LH 81681 - 97203 - 8,600 yen #
    Halogen headlamp right Head lamp ASSY RH 81110-97274- 19,300 yen #
    Halogen headlamp left Head lamp ASSY LH 81150-97274- 19,300 yen #
    HID head lamp right Head lamp ASSY RH 81110-97275- 67,500 yen #
    HID headlamp left Head lamp ASSY LH 81150-97275- 67,500 yen #
    Standard high mount LED stop lamp Center stop lamp ASSY 81570-97222- 8,400 yen #
    Stop lamp gasket Center stop lamp gasket 81554 - 97203 - 1,200 yen # Necessary when reusing lamp
    antenna Rod antenna 86332 - 97202 - ¥ 1,900 #
    Antenna mount Antenna holder 86370-97201- ¥ 1,100 #
    O2 sensor Oxygen sensor No. 2 89465-97205- 22,800 yen #
    Front suspension white cap Bearing dust cover 48684 - 87202 - 180 yen # Supplementary explanation
    Front suspension fixing nut Nut, cap 90041-79307- 150 yen # 2 one side required
    ondert and copenfangrl like this.
  17. Vin Petrol
    Upper mount middle nut Nut, cap 94184-01200-000 100 yen #
    Upper mount right Front suspension support RH 48603 - 97202 - ¥ 3,800 # Supplementary explanation
    Upper mount left Front suspension support LH 48609 - 97205 - ¥ 3,800 # Supplementary explanation
    Upper seat Front spring seat 48470-97203- ¥ 470 # Horizontal common
    Suspension cushion Front spring bumper NO.1 48331-97201- 1,460 yen #
    Bolt fixing the suspension Bolt, hexagon 90041-01634- 280 yen #
    Bolt nut fixing the suspension Nut, Hexagon 90041-70260- 90 yen #
    Oil element Oil filter 15601 - 97201 - 1,500 yen #
    Gasket for oil pan Oil pan drain plug gasket 90044-30281- 160 yen # 12 mm - 19 mm
    Packing for oil filler cap Oil filler cap gasket 90430-37140-000 170 yen #
    Lubrication cap with lid Fuel cap 77300 - 87702 - ¥ 2,200
    Winter wiper right 438 mm Front wiper winter blade RH 85291 - 97207 - 3,200 yen #
    Winter wiper left 382 mm Front wiper winter blade LH 85291 - 87202 - ¥ 2,500 #
    Standard wiper rubber Right 450 mm Wiipara RH 85221-97202- 560 yen # 6 mm wide
    Standard wiper rubber left 400 mm Wiipara LH 85221-97214- 450 yen # 6 mm wide
    Switch cover for seat wearing non-equipped car Spare switch hole cover 55539-48010- 200 yen # 1 piece
    Fog lamp switch old Switch assembly, fog lamp 84160-97203- 3,150 yen # 4P
    Fog lamp switch New Front fog lamp switch 84160 - B 2010 - ¥ 2,470 # 5P
    Switch valve valve 84999-10310- 250 yen # Part number change
    Switch valve valve 9004 C - 81007 - 230 yen # 1 piece
    Engine hanger left Engine hanger NO.1 12281 - 97202 - 900 yen # Used when detaching the engine
    Engine hanger right Engine hanger NO.2 12282-97204- 600 yen # Used when detaching the engine
    Engine bolt 8 x 16 mm With Washer Bolt 91621 - B 0816 - 80 yen # Used when detaching the engine
    ■ 2nd anniversary related
    Red door trim right Front door trim board RH 67610-97294-C0 ¥ 18,100
    Red door trim left Front door trim board LH 67620-97298-C0 ¥ 18,100
    momo steering red Wheel assembly, steering 45102 - 97509 - 45,000 yen Air bag optional
    momo air bag black Horn button ASSY 45104-97242- 35,000 yen
    Seat cushion right Cushion assembly Front seat light 71410-97282-C2 41,600 yen
    Seat back right Back assembly Front seat light 71040 - 97 L 03 - C 2 54,500 yen
    Seat cushion left Cushion assembly Front seat left 71420 - 97 B 09 - C 2 41,600 yen
    Left back seat Back assembly Front seat left 71070-97228-C2 54,500 yen
    Seat heater switch Switch seat heater 84751-97201- 3,150 yen 1 piece
  18. Vin Petrol
    ■ Ultimate Edition related
    Orange door trim right Front door trim board RH 67610 - B 2720 - C 0 16,400 yen
    Orange door trim left Front door trim board LH 67620 - B 2620 - C 0 16,400 yen
    momo steering wheel black Steering Wheel ASSY 45102 - 97506 - 49,500 yen Air bag optional
    momo air bag Orange Horn button ASSY 45130 - B 2340 - 35,000 yen
    Orange seat cushion right Separate type front seat cushion ASSY RH 71410 - B 2070 - C 1 41,600 yen
    Orange seat back right Separate type front seat back ASSY RH 71430-B2120-C1 54,500 yen
    Orange seat cushion left Separate type front seat cushion ASSY LH 71420-B 2110 -C 1 41,600 yen
    Orange seat back left Separate type front seat back ASSY LH 71440-B 2190 -C 1 54,500 yen
    BILSTEIN shock absorber front right Front shock absorber ASSY RH 48510 - B 2690 - 44,700 yen
    BILSTEIN Shock absorber front left Front shock absorber ASSY LH 48520 - B 2690 - 44,700 yen
    BILSTEIN after shock absorber Rear shock absorber ASSY RH / LH 48531 - B 2640 - ¥ 26,800 Left to right
    BILSTEIN emblem Rear body name plate NO.2 52163 - B 2020 - ¥ 1,520 Out of print
    BBS Wheel Silver (Casting) Disk wheel 42611 - B 2320 - ¥ 30,000 One
    Emblem for BBS wheel (56 φ) Wheel hub ornament 42638-97403- ¥ 2000 1 sheet
    ■ Ultimate Edition II related
    Camel door trim right Front door trim board RH 67610-B2A10-C0 16,400 yen
    Camel door trim left Front door trim board LH 67620-B2A20-C0 16,400 yen
    momo air bag camel Horn button ASSY 45130 - B 2430 - 35,000 yen
    Camel seat cushion right Separate type front seat cushion ASSY RH 71410 - B 2070 - C 2 41,600 yen
    Camel seat back right Separate type front seat back ASSY RH 71430-B2120-C2 54,500 yen
    Camel seat cushion left Separate type front seat cushion ASSY LH 71420 - B 2110 - C2 41,600 yen
    Camel seat back left Separate type front seat back ASSY LH 71440 - B 2190 - C2 54,500 yen
    BILSTEIN emblem Rear body name plate NO.2 52163 - B 2021 - ¥ 1,520 69 mm × 34 mm
    Black plating front grill Radiator Grill Garnish 53141 - B 2040 - 13,900 yen
    Ultimate exclusive side emblem right Quarter panel emblem 75371 - B 2010 - ¥ 2,100
    Ultimate exclusive side emblem left Quarter panel emblem 75372 - B 2010 - ¥ 2,100
    Clear body side turn lamp Side turn signal lamp lens 81731-51021- ¥ 930 2 required
    Orange valve T10 12V 5W Side turn signal lamp bulb 90981-15012- 260 yen # 2 pieces required
    Clear Crystal Rear Combi Light Right Tail lamp ASSY RH 81550 - B 2280 - ¥ 10,900
    Clear Crystal Rear Combi Lamp Left Tail lamp ASSY LH 81560 - B 2280 - ¥ 10,900
    Clear high mount LED stop lamp Center stop lamp ASSY 81570 - B 2180 - 9,300 yen
    Shine Black Center Cluster Instrument Cluster Finish Center Panel ASSY 55420-B 2010 - C 0 4,500 yen
    Shine Black Register Bezel Ring Instrument panel register opening cover 55526-B 2010 - C 0 ¥ 750 4 required
    Door Bezel Black Right Front door inside side handle bezel RH 69277-22090-C0 ¥ 620 #
    Door bezel black left Front door inside side handle bezel LH 69278-22050-C0 ¥ 620 #
    Plating inner door handle right Front door inside side handle RH 69205-B 2010 - C 0 1,950 yen
    Plating inner door handle left Front door inside side handle LH 69206-B 2010 - C 0 1,950 yen
    Plating parking brake lever lever button Parking brake lever 46210 - B 2100 - C 0 4,700 yen #
    For white meter MT (with plating ring) Combination meter ASSY 83800 - B 2 N 42 - 49,800 yen #
    For white meter AT (with plating ring) Combination meter ASSY 83800-B 2 N 52 - 51,700 yen #
    Shine Black AT shift panel AT shift panel 08172 - K 2006 - ¥ 7,500 #
  19. Vin Petrol
    ■ Ultimate Leather Edition Related
    momo steering wood Steering Wheel ASSY 45102 - 97505 - 49,500 yen Air bag optional
    BBS Wheel Gun Metal (Casting) Disk wheel 42611 - B 2630 - ¥ 30,000 One
    Black door trim right Panel assembly, door trim, RH 67610-B2C10-C0 16,400 yen
    Black door trim left Panel assembly, door trim, LH 67620-B 2630-C 0 16,400 yen
    Ivory door trim right Panel assembly, door trim, RH 67610-B2C20-C0 16,400 yen
    Ivory door trim left Panel assembly, door trim, LH 67620 - B 2640 - C 0 16,400 yen
    Genuine leather black seat cushion right Separate type front seat cushion ASSY RH 71410-B 2110 -C 1 48,100 yen
    Genuine leather black seat back right Separate type front seat back ASSY RH 71430 - B 2180 - C2 ¥ 61,000
    Leather black seat cushion left Separate type front seat cushion ASSY LH 71440-B 2160 -C 1 48,100 yen
    Leather black seat back left Separate type front seat back ASSY LH 71440 - B 2270 - C 1 ¥ 61,000
    Genuine leather ivory seat cushion right Separate type front seat cushion ASSY RH 71410-B2120-C0 48,100 yen
    Genuine leather Ivory seat back right Separate type front seat back ASSY RH 71430-B 2190 -C 1 ¥ 61,000
    Leather Ivory Seat Cushion Left Separate type front seat cushion ASSY LH 71420 - B 2170 - C 0 48,100 yen
    Leather Ivory seat back left Separate type front seat back ASSY LH 71440 - B 2280 - C 0 ¥ 61,000
    ■ Daihatsu Copen Service Manual (maintenance manual)
    New model car manual Copen New Model Car No.1 EU111A 4,000 yen June 2002
    Additional version manual of new car Copen new model car manual number 2 EU121A 400 yen February 2003
    Repair manual Copen repair book No. 1 JU111K ¥ 7,100 July 2002
    Repair note additional version Copen Repair Manual No.2 JU121K ¥ 1,000 February 2003
    Repair note additional version Copen repair card No.3 JU131K 600 yen December 2005
    Repair note additional version Copen repair manual No.4 JU141K ¥ 1,300 August 2010
    Sheet metal repair manual Copen Body Repair No.1 PU 111A 4,400 yen August 2002
    Wiring diagram collection Copen wiring diagram No.1 QU 111A ¥ 5,100 June 2002
    Wiring diagram collection Copen wiring diagram No.2 QU121K 900 yen August 2010
    ■ Daihatsu genuine parts
    Remote control key for Move L900 Transmitter door 89071 - 97204 - 000 ¥ 8,800 Blank key
    Supply Battery Set Battery set, transmitter 89706 - 87401 - 500 yen #
    Antenna for YRV Pole subassembly antenna 86309-97401-000 ¥ 2,350 Glossy
    Rubber hose for washer hose 85375 - 87502 - ¥ 630 1 m
    Air conditioner filter Holder Assembly, Air Filter 88980-97201-000 ¥ 2,650
    Air conditioner filter filter only Filter, air 88568-97201-000 ¥ 730 #
    AM radio noise countermeasure item Terminal, Earth 82675-97201-000 ¥ 1,320 # Reference page
    Security sticker (large) Theft warning plate 74515-B2010- 170 yen 83 × 28 mm
    Security sticker (medium) Theft warning plate 74515 - B 2030 - 160 yen 60 × 21 mm
    Security sticker (small) Theft warning plate 74515 - B 2040 - 160 yen 50 × 17 mm
    Lead-free label for Hong Kong and Macao Label, Unreaded Fuel Information 74579 - 87601 - 160 yen 60 × 60 mm
    High-octave label (unleaded premium) Label, fuel information 74559 - 97202 - 000 170 yen 60 × 41 mm
    Mcguard Navigation Lock Rock, tapping set 08667 - K 9000 - ¥ 2000 M5 × 15 mm tapping
    Lubricated lubrication cap (without print) Fuel tank cap ASSY 77300-52030- 1,440 yen # One click type
    78 ° C valve opening thermostat thermostat 90048-33085-000 1,490 yen # For story X4
    1.3 kg / cm 2 (127 kPa) radiator cap Cap subassembly, radiator 16401-97201-000 ¥ 1,870 # For story X4
    Coin holder Remote control mirror hole cover 55547-42020-C0 550 yen # 41 × 50 mm
    Coin holder Instrument panel coin box 55441 - B 2020 - ¥ 650 #
    Penholder Spare switch hole cover 55539-52020-C0 310 yen #
  20. Vin Petrol
    ■ Toyota genuine parts
    Side marker lens Side turn signal lamp lens 81731-51021 ¥ 930 2 required
    Orange valve T10 12V 5W Side turn signal lamp bulb 90981-15012 260 yen # 2 pieces required
    Short antenna Roof antenna pole SUB-ASSY 86309-12150 ¥ 2,090 Glossless
    Long spiral antenna Roof antenna pole SUB-ASSY 86309-13010 ¥ 1,900 # No gloss
    Long spiral antenna Roof antenna pole SUB-ASSY 86309-52040 ¥ 1,900 # Genuine same size · glossy
    Belt guide tape set Belt guide tape 73205-48011 1,540 yen 2 sheets set
    Antistatic kit Antistatic plate 08172-00040 ¥ 2000 Manufacturer name engraved
    Plated side brake knob Parking brake Release rod knob 46217-53010 180 yen 31 × 13 mm
    MR-S wind exit switching label Heater control sheet 81942-17170 190 yen # Supplementary explanation
    MR-S air volume label Heater control sheet 81942-17190 190 yen # Supplementary explanation
    MR-S wind temperature label Heater control sheet 81942-17160 190 yen # Supplementary explanation
    Burglar alarm with sticker Auto alarm label 08586-00010 240 yen 112 × 35 mm
    Security sticker Label, auto alarm 08586-00020 ¥ 1,000 83 × 29 mm
    Completed FY2010 fuel efficiency standard car sticker Fuel Conserption Information Label 74561-52010 170 yen #
    Air bag warning label Passenger airbag caution label 74598-20010 80 yen Diameter 50 mm
    Regular specification label (lead free) Fuel information label 74559-14050 80 yen 39 × 17 mm
    Regular specification label (unleaded · English and French notation) Fuel information label 74559-14060 170 yen 63 × 23 mm
    High-octane label (unleaded premium) Fuel information label 74559-50010 100 yen 65 × 27 mm
    High-octane label (unleaded premium · British and French notation) Fuel information label 74559-20110 110 yen 63 × 40 mm
    5 speed MT shift pattern Control lever information label 33621-53020 280 yen # 22 × 16 mm
    Lubrication cap hook Fuel tank cap hanger 77399-53010 190 yen 30 × 29 mm
    Filler cap holder Fuel tank hanger 77399-28010 350 yen 54 × 29 mm
    Lubricated lubrication cap with a string (brown alphabet) Fuel tank cap ASSY 77300-48010 ¥ 1,330 #
    Lubricated lubrication cap (alphabet) Fuel tank cap ASSY 77300-53010 1,780 yen
    Lubricated lubrication cap (without print) Fuel tank cap ASSY 77300-28010 ¥ 1,610 #
    No sticker lubrication cap (alphabet) Fuel tank cap ASSY 77310-48020 ¥ 2,910 #
    Lubricated lubrication cap (without print) Fuel tank cap ASSY 77300-52030 1,440 yen # One click type
    Lubricated lubrication cap (alphabet) Fuel tank cap ASSY 77300-52040 1,440 yen One click type
    Printed engine oil filler cap Oil filler cap SUB - ASSY 12180-21021 590 yen API SL SAE 5W-30
    Printed engine oil filler cap Oil filler cap SUB - ASSY 12180-46031 590 yen # API Notation
    Lamp for trunk Room lamp ASSY NO.2 81250-12030-B5 ¥ 1,970 Required processing
    Two-hole washer nozzle Washer Nozzle 85381-30030 - ## ¥ 970 Silver (B2), white (A1)
    Two-hole washer nozzle Washer Nozzle 85381-30020 - ## ¥ 970 Silver (B2), Pearl White (A4)
    Three-hole washer nozzle Washer Nozzle 85381 - 53050 - ## 990 yen Each color
    Four-hole washer nozzle Washer Nozzle 85381-22010 - ## 800 yen Each color
    W2 hole washer nozzle Washer Nozzle 85381 - 58020 - ## ¥ 720 Each color
    Diffusion type washer nozzle Washer Nozzle 85381 - 33060 - ## ¥ 1,100 Each color
    Diffusion type washer nozzle Washer Nozzle 85381 - 50060 - ## ¥ 1,100 Each color
    Shift knob for Lexus IS-F Shift lever knob 33504 - 5300 - C 0 3,580 yen For AT vehicles (M8 x 1.25)
    Cigar Socket Cap Cap ASSY 85535-47010 350 yen # 12V / 120W MAX
    Coin holder Instrument panel coin box 55441 - 52040 - C 0 270 yen # Short
    Coin holder Instrument panel coin box 55441 - 44020 - C 0 400 yen # Long
    Door Bezel Kuroki Tone Right Front door inside side handle bezel RH 69277-44020 ¥ 690
    Door Bezel Kuroki Tone Left Front door inside side handle bezel LH 69278-44020 ¥ 690
    Door bezel Kuroki eye screw hole hole lid Front door inside handle handle bezel plug 69283-44010 120 yen #
    Door bezel brown wood grain tone right Front door inside side handle bezel RH 69277-44040 ¥ 690
    Door bezel brown wood grain tone left Front door inside side handle bezel LH 69278-44040 ¥ 690
    Door bezel brown wood grain adjustment screw hole lid Front door inside handle handle bezel plug 69283-44020 120 yen #
    Door Bezel Silver Right Front door inside side handle bezel RH 69277-44060 ¥ 690
    Door Bezel Silver Left Front door inside side handle bezel LH 69278-44060 ¥ 690
    Door bezel silver screw hole lid Front door inside handle handle bezel plug 69283-44030 120 yen #
    Plating door handle right (inside) Front door inside side handle RH 69205-44030 2,150 yen Lock also plated
    Plating door handle left (inside) Front door inside side handle LH 69206-44030 2,150 yen Lock also plated
    Plating door handle right (inside) Front door inside side handle RH 69205-22080-C 0 2,150 yen The lock is black
    Plating door handle left (inside) Front door inside side handle LH 69206-22080-C 0 2,150 yen The lock is black
    Plating door handle right (outside) Outside door handle RH 69210-12250 ¥ 3,860
    Plating door handle Left (outside) Outside door handle LH 69220-12250 ¥ 3,860
    Aero wiper blade 475 mm Wiper blade 85222-30580 ¥ 2,400 #
    Wiper change rubber 475 mm Wiper rubber 85214-30390 800 yen #
    Aero wiper blade 450 mm Wiper blade 85222-30590 2,180 yen Genuine right size
    Wiper change rubber 450 mm Wiper rubber 85214-30400 800 yen 8.6 mm width
    Aero wiper blade 425 mm Wiper blade 85222-42100 1,980 yen #
    Wiper change rubber 425 mm Wiper rubber 85214-42050 ¥ 750 #
    Aero wiper blade 400 mm Wiper blade 85222-28160 ¥ 1,810 Genuine size for left
    Wiper change rubber 400 mm Wiper rubber 85214-28090 ¥ 750 8.6 mm width
    copenfangrl and ronalddoes like this.
