Car stereo double DIN
Discussion in 'General Chat' started by Kagu, Aug 9, 2018.
  1. Kagu
    Kagu Copenworld Newbie
    France
    Hello, I am looking for a car stereo double DIN that fills the entire location as in this picture. Alpine IVE-W530BT.png
  2. Elem
    Elem Copenworld Newbie
    Finland
    Daihatsu Copen 1.3 LHD 2006, Toyota Porte 150R 2008
    Hi Kagu,
    Try searching for "2DIN car stereo" or the like from Ebay for example. I got the 2DIN head unit in the end of this post from Ebay. It's an Xtrons Android 8.0 unit. It almost fills the entire hole, but there will remain a small gap like in the picture below from my dash:
    Vin Petrol likes this.
  3. Kagu
    France
  4. AFR0N1
    Measure the size of the space in the dashboard and compare with the dimensions the head unit you want to buy. That way you will know if it will fill in the entire space or not.
  5. Elem
    Finland
    All double-DIN units are very close the same standard size I believe. What could make the difference, is a possible bezel adaptor that I think is present in the photo in Kagu’s orginal post. There was no adaptor with my stereo and still the gap is just a couple millimeters in the sides, less so above and below, close enough for me. A possible adaptor should be meant for Copen, could prove hard to find?
  6. Kagu
    France
  7. Elem
    Finland
  8. jagr
    jagr Copenworld Newbie
    cheshire
    '58 Copen 1.3
    '05 Boxster 2.7
    '07 BMW X3 3.0sd
    IMG_3404.JPG This my Kenwood double din. It very nearly fills the gaps.
    Kagu likes this.
  9. Kagu
    France
    I ordered the car radio I was talking about. I'm a little stressed by one because it is a Chinese model and the other at the waist! If it's good I'll put you pictures.
  10. Kagu
    France
    Well, I received and installed the car radio quickly to see the result.
    It is a little on the right because of the brackets that the former owner had slaughtered by cutting to put his car radio:mad: and finally as he could not put it he put a cage to make it stand or marks on the plastic:swear:
    The car radio is level with the front panel by the volume knob of course.
    I wish he was full in the front but the result is correct.
  11. Anji
    Anji Copenworld Member
    Buckinghamshire
    Here is a Pioneer double din
  12. Big Red
    Big Red Copenworld Newbie
    Cyprus
    Copen 660
    My Copen is a Japanese import and the radio only picked up a couple of channels so, yesterday, I had a Pioneer AVH-X390BT fitted. Looks pretty good and works well. 20180901_152157.jpg
