break light in boot lid leaking
Discussion in 'Introductions' started by Giles Trussler, Feb 24, 2017.
  1. Giles Trussler
    Giles Trussler Copenworld Newbie
    uk
    evoque, ranger, jeep wrangler copen
    Hi, does anyone know the best fix for a leaking light in the boot lid.
  2. welz
  3. wellung1
    wellung1 Copenworld Newbie
    UK
    Copen 1.3, BMW 220d
    Ours has "water" in the boot that comes from condensation dripping off the boot lid overnight. Buy a cheap silica bag off t'interweb and see how you get on before trying the (very, very annoying) job of replacing the seal. We did the silicon reseal of the brake light and then found out it was condensation...
  4. JanesAddiction
    W Mids
    1.3 Copen
    The gasket is over £30 and on mine didn't even work, I ended up making one myself out of a 5mm rubber draught sealer.
  5. BarnsleyRob
    Did you use the double-sided foam stuff or something else ?
  6. JanesAddiction
    W Mids
    1.3 Copen
    It was only sticky on one side, I had to trim it, but it worked and was much cheaper than the original which came much to thin. The foam I used was 5mm but 3 or 4mm would be fine.
  7. BarnsleyRob
    Good tip. Thanks for posting.
