Boost controller
Discussion in 'Problems, Fixes, Tips...' started by Mark Chen, May 31, 2012.
  1. Mark Chen
    Mark Chen Copenworld Newbie
    Singapore
    Daihatsu Copen 660CC
    Opel Combo
    Hafei
    Hyundai
    Does Copen come with boost controller?
    Nope, you need to buy an aftermarket boost controller if you want to up the boost.
  3. Adam K
    Don't increase the boost too high or the standard ecu will cut in to protect the engine.
    You need to buy a sports ECU or an FCD (fuel cut defender) to get around this.
    You should also fit a decent boost gauge so you know what boost you are running.
  4. Mark Chen
    Singapore
    Opel Combo
    Hafei
    Hyundai
    Hi Adam, thanks for the advice... looks like the original boost is about 1.1 correct?
  5. Adam K
    To be honest, I thought the standard boost was less than that.
    Maybe a previous owner has already fitted a boost controller?
  6. ex-xr
    ex-xr Copenworld Newbie
    Copen RHD 659 cm³, Ford Escort convertible 1.8 RHD (for summer); Toyota Yaris D4D (Winter)
    As far as I know the boost is 0.9! I've red it somewhere...but I dunno where.:eek:
    Greets
    ~Felix~
  7. terry urwin
    terry urwin Copenworld Newbie
    consett
    yes vivid
    hi just fitted my boost controler standad boost is 0.8/0.9 running mine at 1.3bar any more will shut the fuel off from the ecu as it thinks it has a turbo problem hope this helps......
