Has anyone had a problem with the air conditioning leaking refridgerant on the turbo engined Copen? I put mine in for a recharge today. They've told me there is a leak somewhere but they don't know where from.
AC Leaks I havent had AC for a year now, there is obviously a leak somewhere but I haven't been bothered to take it for a test as in the summer the roof is down most of the time. I guess in the winter I will miss it for the demisting. I thought about buying one of the DIY AC filler cans from Ebay but in the long run if there is a leak I will need to get it fixed. Did you have any luck with yours?
Apparently, Queen Elizabeth I took a bath every 3 months - whether she needed one or not! I assume that you guys know this - but for those who don't, it is important to run the AC in your car every now and again - whether you need it or not. The reason is that the seals in the AC pump dry out if the AC is not used then coolant leaks and no more AC - it is an expensive fix. I try to run the AC at least once a month (more often if I remember). If you are feeling cold, it is okay to turn the heat up while the AC is running.
Got mine fixed. Turned out it wasn't a leak, just a corroded wire connection to the compressor. Had to take the front bumper off air box to get to it. Then it just needed re-gassing.
