Tonneau Cover
Discussion in 'For Sale' started by Michaela, Aug 1, 2010.
  1. Michaela
    Michaela Copenworld Newbie
    Tonneau Cover with Rear Panel & Clips on eBay ends 18.00hrs Today!
    Michaela.
  2. copenworld
    Auckland, NZ
    Good luck, that's quite a bargain - I paid nearly £400 for mine! :eek:
  3. theroo
    theroo Copenworld Newbie
    Rossendale, Lancashire
    2009 Copen 1.3
    I got the bargin
    I bought the tonneau cover on ebay and it looks a treat on the car. A bargin indeed.:D
  4. Ken
    Ken Copenworld Member
    Pleased you like it!
    Ken.
  5. Jaromir
    Jaromir Copenworld Newbie
    Where did you buy the persenning wiht the clips?
    my Copen is not prepared yet to have a persenning, so it needs some holes drilled... do you guys think it is a lot of work?
  6. theroo
    2009 Copen 1.3
    Hi,
    If you put the cover on the car and where the hole in the cover meet the car if you push a small screwdriver or similar through the fabric the holes are already in the metal frame.
    Hope that helps. It took me 10 minutes to fit the fixings. Looks great when done.
  7. Jaromir
    Do you maybe have a picture of how it looks now? without the tonneau cover
    where did you screw in the holes? how did you secure them?
    I tried to search today, but I could not find any pre drilled holes...
    so I was wondering if you could make a picture for me.
    that would be awsome.
    Greetings Jaromir
  8. theroo
    2009 Copen 1.3
    Hi,
    No pictures at the moment but if you run your fingers under the ledge you should find the holes for the screws. You will have to put a hole in the felt that covers the crossbeam though.
    Hope that helps.
  9. Jaromir
    Did you support the holes you made with rings? or did you just made holes?
    because otherwise they maybe get bigger, etc...
