lCopen problem
Discussion in 'General Chat' started by Hursaa, Dec 17, 2014.
  1. Hursaa
    Hursaa Copenworld Newbie
    UK
    Octavia vrs
    Hi Guys,
    My Copen's engine management light has come on and after taking it to the garage I have been informed that the Lambda Sensor has gone. Had a quote for "genuine part £200 or there about". Anybody had this problem before and if so where to purchase this sensor at a realistic cost :-((
  2. Number6
    Number6 Copenworld Veteran
    Lamda sensors are also called O2 sensors. There are two in the Copen. Do you know which one has gone?
  3. Hursaa
    UK
    Octavia vrs
    Thanks for reply,
    The sensor before the cat has gone, It's the grey one!!
  4. Number6
  5. Hursaa
    UK
    Octavia vrs
    Thanks, I will look into it:)
  6. Nedryerson
    Nedryerson Copenworld Regular
    It's not right what garages charge for simple repairs.
    I recall I had a flat spot with my 1.9 turbo Bora which was down to a sensor problem. The sensor (which was nothing more than a simple thermistor) cost next to nothing off EBay and installing it took around 15 minutes.
    I was at the VW dealer later on and overheard a customer being quoted £400.00 for the same job.
    Well, somebody has to pay for the showroom and the free coffee,
    Ned
  7. threepot
    threepot Copenworld Regular
    Just use a universal 4 wire sensor and solder the connector on.
    I do it for pretty much all Daihatsu's because they are a bitch to get direct fit lambda sensors.
    You can buy a Bosch or Denso 4 wire univeral lambda sensor for about £30 from the likes of Eurocarparts.
    The only difference between a univeral sensor and a direct fit sensor is that one comes with a plug on the end.
  8. Number6
    Are you bloody serious!? Would there be any issues with using a universal for the MOT? The Irish MOT is very very strict on emissions, so I never bothered with universal parts.
  9. threepot
    Why do you think they would be different?
    ALL Lambda sensors output exactly the same.
    I would have thought you know this.
    Just don't buy any cheap Lambda sensors, I only buy Denso, Bosch, and at a push Walker. Cheap ones don't last very long.
  10. Number6
    Very true, I never really looked too much into the emissions systems as our MOT is a minefield for that area of a car's road worthiness (along with rust).
    I do believe you have saved everyone here £100 if they know how to solder!
  11. threepot
    Most people just crimp the wires - universal sensors come with a set of crimps for the job. I prefer to solder them though because I am a tart like that.
  12. Number6
  13. Colinthecupboard
    Colinthecupboard Copenworld Newbie
    Shropshire, UK
    Daihatsu Copen, Hyundai i30, Fiat 500
    Thanks for all the above, helped a lot, I have read with interest & have also read other threads and researched widely over the web. Given that my original wire connector plug is melted a general fit part seems just the job so I have ordered a Denso DOX 113 (pre cat) sensor. Will report back with any problems otherwise £37 well spent !
