Front Fog Light Buld Replacement
Discussion in 'Problems, Fixes, Tips...' started by jmaboko@gmail.com, Sep 20, 2012.
Does this post help?
  1. Yes thanks !
    100.0%
  2. I knew this all along...
    0 vote(s)
    0.0%
  3. No, go fly a kite.
    0 vote(s)
    0.0%
  1. jmaboko@gmail.com
    jmaboko@gmail.com Copenworld Newbie
    Hi all
    I recently discovered that my front fog light lens was hit by a stone while I was driving on the highway:-((. As a result rain water was getting into the fog light.
    After a few days the fog light bulb stopped working and I had to replace it. :-((
    Attached are pictures of how i replaced the front fog light bulb.:cool:
  2. Coxsie
    Coxsie Copenworld Member
    Watford Herts
    Copen + Signum
    Hi jmaboko,
    Thanks for the Photo sequence, it will be handy for anyone who has a similar problem.:):)
    Nice one
  3. Adam K
    Photo guides are always helpful. Nice work.
  4. terry urwin
    terry urwin Copenworld Newbie
    consett
    yes vivid
    hi if you turn the wheel fully left or right you just have to undo bottom clips and pull wheel arch cover behind the wheel you can get your arm in to reach bulbs...
  5. beltrichard
    beltrichard Copenworld Newbie
    wheel arch clips
    Im trying to replace the bulb light and got stuck at the first hurdle,
    Does anyone know how to undo the bottom clips to pull back the wheel arch cover?
    thanks a lot,
  6. Adam K
    Hi Beltrichard, Welcome to Copenworld.
    If I remember correctly, you'll need a flat blade screw driver. The round plastic head of the fixing has another circular dot in the middle. Use the flat blade screw driver to prize out the centre dot (it's a pin). Once the pin is lifted you should be able to pull the fastener out.
  7. Ashley
    Ashley Copenworld Member
    Cape Town
    Merc estate
    RAV4 3-Door
    Bad luck - how much did the replacement lens cost?
    To reduce the risk of this happening, I've recently had my headlights and fog lamps covered with clear vinyl, by the guys who do window tinting (AKA "smash & grab" here in SA) - also has the effect of keeping the light lenses looking like new - rather than sand-blasted.
