Chrome seatbelt guides?
Discussion in 'General Chat' started by penlanone, Jul 11, 2012.
  1. penlanone
    penlanone Copenworld Newbie
    IOW
    Copen (Arrr)
    Zafira (ugh!)
    BMW F650 CS (Yum)
    Does anyone know if the replacement, chrome seatbelt guides are available and where I may find some? Cheers.
  2. copenworld
    Auckland, NZ
    There's some information on the features page about where I bought mine, and a short photo guide to fitting them - which is very simple!
    I imported mine to the UK from Japan, but that was quite a while ago now, so other members may know of other options.
  3. Adam K
  4. Binz
    Binz Copenworld Regular
    North Hampshire
    I have the cromdesign ones. The Kumoi look a lot better imho but as they were sold out I went for the others. The belts used to fold and get stuck in the original plastic guides; in the chromdesign ones the guide is larger so they don't get stuck (although the belt retraction is still slow, but that's not due to the guides). They didin't come with bolts so reused original black ones then got some stainless steel ones from local bolt shop.
  5. penlanone
    IOW
    Copen (Arrr)
    Zafira (ugh!)
    BMW F650 CS (Yum)
    Thanks people. Seems like Copen extras start @ £150 a pop! How easy is it to order from Japan? Anything to be aware of?
  6. Adam K
    I can give you a contact for a guy I use to import.
    He'll give you a proper quote with a breakdown of the costs.
    You'll need to pay import tax on top when the parcel enters the UK.
  7. nertman
    nertman Copenworld Regular
    Braintree Essex
    57 plate copen
    Customised MGTF
    Nissan Terrano
    Suzuki GSR
    Kawasaki W800
    hold on guys
    should know by the end of the weekend if we can get mk3 mazda mx5 ones to fit!
    in standard black plastic they are 11 pounds each and i believe aftermarket chrome ones can be soursed for under 40,
    just waiting for a set to arrive,(have tried with partly damaged one and it worked well ,no snagging etc)
  8. Clothcat
    Clothcat Copenworld Newbie
    God, my seatbelts drive me MAAAAAAD! My husband ALWAYS yanks his out of its guides, and I got so fed up with mine I don't use the guides at all now - how quickly the belt now retracts! Any solution to this maddening issue would be worth pursuing!
  9. Adam K
  10. penlanone
    IOW
    Copen (Arrr)
    Zafira (ugh!)
    BMW F650 CS (Yum)
    Mazda guides ...
    nertman - will be interesting to hear if the Mazda guides fit. Are the hole centres the same then? Are these the type?
  11. Ashley
    Ashley Copenworld Member
    Cape Town
    Merc estate
    RAV4 3-Door
    I figured out a work-around...
    At around 6ft, I need the seat all the way back to get in or out of the car
    I pull the seat forward before fastening the seat the seat belt then adjust the seat back to where I need it. This stops the belt twisting in the guides.
    Then I pull the seat forward before disconnecting the seat belt, let it retract then move the seat all the way back so I can get out of the car.
    Mostly this works fine and the seatbelt does not twist and jam. :cool:
    Occasionally, they twist and jam anyway, so it's not foolproof. :eek:
  12. nertman
    Braintree Essex
    57 plate copen
    Customised MGTF
    Nissan Terrano
    Suzuki GSR
    Kawasaki W800
    mazda type
    yes i believe they are,
    A fellow nert member has some on order for his mx,hence we can try when they arrive,
    also the chrome air vent rings should be comming and i think these fit as well
    May require some minor mods but if it works ,cheaper and more readly available
  13. penlanone
    IOW
    Copen (Arrr)
    Zafira (ugh!)
    BMW F650 CS (Yum)
    Excellent - do let us know when you have a result. I'll hold off ordering from JP for now then. £18 squid form here Cheers!
    Any news nertman? :)
  14. alz2605
    alz2605 Copenworld Regular
    Ceredigion
    VW Golf TDi
    Did these work out? Did they need any modifying?
