0.7 or 1.3L
Discussion in 'General Chat' started by Number6, Jun 27, 2013.
  1. Number6
    Number6 Copenworld Veteran
    The 0.7L seems to be a far more common sight to buy than that 1.3L.
    Apart from the differences in engine size, the lack of a turbo and longer service times on the 1.3L, are the any other differences between the models?
    Initially I have been giving a lot of thought to the 1.3L, but if the above are the only differences between the two models, the 0.7L would make far more sense.
    Thoughts?
    The 1.3 comes with a spoiler fitted as standard.
  3. trustafox
    you have more colour options with the 0.7
    the 1.3 is quick 0-60 and I don't find its strained doing motorway speeds that write ups say about the 0.7. Its higher revs at same speed so is noisier also.
    If you want to up the power then you can make quite a lot more and simply with the 0.7.
  4. RHD
    RHD Copenworld Member
    West Midlands
    Saab 9-3
    0.7
    The 1.3 also gets an ugly spoiler.
  5. trustafox
    the spoiler stops it looking like a push-me-pull-you
    but I think Noddy is with you on this one
  6. dsb
    I bought a spoiler for my 0.7 - still waiting to fit it though!
  7. trustafox
    is it ready painted?
    whats the hold up?
  8. dsb
    The hold up is that I have to drill holes in the boot - stupidly it never occurred to me
  9. trustafox
    scares you to do it?
  10. trustafox
    well as its aluminium, rust won't be a problem where you have bare metal in the hole. as long as it basically stays dry. does it have a seal to go between the wing and boot surface?
  11. PauliePaul
    PauliePaul Copenworld Regular
    Bedford
    my vivid has a spoiler and i think they look better then without ;)
  12. dsb
    the spoiler does come with some sort of sealant.
    my plan is to get the garage to do it when it's serviced.
